shock bushings
[Closed] shock bushings
[#2770227]
bought a santa cruz superlight 4 months ago and the shock bushings have worn out already ... there is alot of play with the rear swing arm 1 is this normal to wear out so quickly ???
richie
Posted : 19/05/2011 8:23 pm
 jad
I'm with you on this. Bought a Yeti ASR5 and after 4 weeks, the lower shock bush was sloppy. Made of cheese.
Posted : 19/05/2011 8:26 pm
seems odd to me how much is shock bushings ??
Posted : 19/05/2011 8:30 pm
few quid but seeing as you're going to be doing it quite often 🙂 you might as well buy a proper tool. Makes it so much quicker!
edit: i've got this one, there are various similar ones about tho
http://forums.mtbr.com/showthread.php?p=4262621#post4262621
Posted : 19/05/2011 8:41 pm
cheers might just do that 🙂
Posted : 19/05/2011 8:56 pm
doesnt sound normal to me in my limited experiance,,,, unless your uber-gnarl.
had this problem with an orange five. turns out (in my expert opinion 😉 ) that one of the bearings had collapsed on the drive side. im thinking that this was the cause of the problem, the single pivot not to be working as it should and maybe causing more load on the bushes,,, i havnt had the same prob since.
also check rear triangle for alignment (if that applies to your bike,,, think it does) as this could also cause probs.
Posted : 19/05/2011 8:59 pm
 StuE
Doesn't seem normal to me - just replaced one on my ASR (polymer one from TFT) for the second time in 6 years...
Posted : 19/05/2011 10:58 pm
when I took the shock off and moved the swing arm without a shock there was still alittle bit of play on the single pivot itself !
Posted : 19/05/2011 11:01 pm
Sounds like the main suspension pivot's shot, that movement will take out your shock bushes pretty quickly, and will eventually do your shock as well if you don't sort it.
Posted : 20/05/2011 7:18 am
