Can't you just use an o ring?
Posted : 27/03/2010 6:30 pm
measure the diameter of the part labelled 'axle/pin' then go to a hardware shop or plumbers supplies and ask for a couple of O-rings that diameter, should only cost pennies!
Posted : 27/03/2010 6:32 pm
erm yes but the o ring will be a lot more flexy whereas the seals here are fairly hard so the forces on the end of the shock would squish the o ring and soon render them useless..? or allow the shock/spacers to move and lead to premature wear..?
my shock is slightly pissed in the mounts so it hammers the seals double quick hence the need for hard wearing ones..
Posted : 27/03/2010 6:36 pm
