Shimano XT/SLX 10sp...
[Closed] Shimano XT/SLX 10spd Double Chainring 24t - Part Number......pleeeeease!
[#4551811]
Anyone out there know which chainring part number I need to stick a 24t granny on my XT M785 double? I'm too fat for the 26t....???????
Thanks
Chris
Posted : 12/11/2012 10:40 pm
I think i remember reading that the 38t ring on the 38/24 crankset is different to the 38t ring on the 38/26 crankset.
I think it had something to do with the ramp profiling to enable the bigger jump in size between rings.
*edit*
Found the Shimano parts listing, there are two different 38t rings:
[url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/FC/EV-FC-M785-3165A_v1_m56577569830800932.pdf ]M785 Tech Doc[/url]
Posted : 12/11/2012 10:47 pm
Silver or Black?
Posted : 12/11/2012 10:48 pm
Madison don't appear to be listing it. If they were, it would be part # 1ML 2400
Yeah don't seem to have them. Might be worth emailing Madison.
Here's the [url= http://cycle.shimano-eu.com/media/techdocs/content/cycle/EV/bikecomponents/FC/EV-FC-M785-3165A_v1_m56577569830800932.pdf ]Tech Docs[/url]
Posted : 12/11/2012 10:54 pm
Either way, I'm pretty sure that he'll need to replace his 38t ring as well.
Posted : 12/11/2012 10:57 pm
mlucas666 - Member
POSTED 5 SECONDS AGO # REPORT-POST
+1
Your not going to get a mech that will work with a 24/38 rings without rubbing, 24/36 is about as wide as you can go.
Posted : 12/11/2012 11:01 pm
madison list 1mm2400 chainring. for the m780 chain set. £19.99 and in stock. [u]might[/u] be compatible.
Posted : 12/11/2012 11:02 pm
Thanks all, maybe I need to get fitter lol.....
Posted : 12/11/2012 11:50 pm
Yeah, you'll need a matched pair of AM38 and AM24 chainrings for the smoothest shifting. The 38/24 M785 combination has only just come out, and I haven't seen anyone offering the chainrings separately yet - may have to wait a while. Could probably get away with the M780 24 ring in the meantime, or even the SLX M675 24 ring, but won't be as good shifting as the proper M785 24/38 matched set.
Utter tosh - Shimano offer the 24/38 as a stock combination now in both SLX and XT, and it works perfectly with the their 2x10 mechs. Just like the old SLX M665 22/36 worked great with the same jump of 14T.
Posted : 13/11/2012 12:23 pm
