Could I run Magura Marta SL rotors with Shimano XT M775 Calipers?
Posted : 06/11/2009 5:26 pm
If you are not going to use the rotors I don't suppose you are going to part with them? Are they c-lock or 6-bolt?
Posted : 11/11/2009 2:26 pm
As long as the rotor diameters are the same, i don't see why not.
Posted : 11/11/2009 2:57 pm
I'm using Hope Floaters with my XTR calipers so I don't see why not. The thickness of discs is almost universal (about 2mm) so as bigyinn says as long as the diameter is the same then it should be ok
Posted : 11/11/2009 3:41 pm
Thanks for replies
For rnewell1973
The rotors are 6 bolt 180mm and 160mm they are not definatly for sale yet i'll wait until i get the magura's running.
Posted : 15/11/2009 6:29 pm
