Shimano XT brake pa...
[Closed] Shimano XT brake pads
[#509718]
The SO has XT calipers on her bike - they are about 4 years old so I think they have changed. The pads have the hole for the pin at one end, not the middle.
The pin is an allen bolt that you screw in, secured by a mini R clip - or was, until the R clip was lost
All new pads I have seen come with a split pin - is this what I am meant to use as a replacement for the screw in pin? Or where would I find a mini R clip
cheers
Posted : 28/04/2009 4:45 pm
i think the clip is just an extra security measure, the split pins can be used instead of the bolt, but the bolt's better if you still have it.
Posted : 28/04/2009 4:47 pm
Split pins as used on LX? They are a very good solution. (Simple engineering is often the best solution). They have to be only "set" about 1-2mm, enough to prevent them falling out, and thereafter will spring into line when you remove them, and are very easy to re insert.
Re-use the same pin forever.
Posted : 28/04/2009 5:04 pm
Shimano part number Y-8CL 98070 (Pad Axle & Snap Ring) for the pin and the "R" clip. I don't like the split-pins!
Posted : 28/04/2009 5:37 pm
