Shimano XT and XTR ...
[Closed] Shimano XT and XTR compatibility advice
[#5206799]
Can I use my current XT triple chainrings and bottom bracket (Shimano M770) with a pair of XTR M970 Cranks?
I'm aware that a special tool is needed to fit the non-driveside crank on the M970 XTR.
Thanks in advance,
Paceman
Posted : 31/05/2013 5:24 pm
BB yes, rings no.
All Shimano HT11 BBs are interchangable but XTR had some funny bolt patterns on the chainrings.
Posted : 31/05/2013 5:25 pm
BB yes, ring - I believe so, they are standard 104, 66 BCD I believe.
Posted : 31/05/2013 6:45 pm
Yes for the rings but you'll need 2mm spacers for the 22t.
Posted : 31/05/2013 7:18 pm
 gee
As above - BB yes, 42/32 will fit but the XTR granny was specific - any other ring needs spacers.
I have a part worn M970 set in the garage I think? If you want them drop me an email on georgebudd1 AT gmail.com
Posted : 31/05/2013 7:30 pm
Thanks guys.
Gee, might be in touch, will see what I have lurking in the shed first.
Paceman
Posted : 31/05/2013 9:33 pm
You can user the inner ring, just needs 2mm spacers as Gee says - I ran TA rings on my M970s.
Posted : 31/05/2013 9:42 pm
Are the 2mm spacers easy to get hold of?
Posted : 01/06/2013 8:13 am
