Shimano XT 2*10 Cha...
[Closed] Shimano XT 2*10 Chainset - chainrings
[#4508827]
Right, probably a really daft question, but can the chainrings on a Shimano double chainset be swapped for different sizes?
I'm just not strong enough to use the 38 tooth outer ring much and like my 22 tooth granny ring on my 2*9 speed set-up so I reckon I'm looking for a 24/36 double rather than the 26/38 available.
I see that the shimano double front mech is for a 38-44 outer - is that recommended or 'has to be obeyed'?
Also, it's for my good old 2005 turner 5-spot - am I as well using a triple with the outer removed?
Cheers!
Posted : 30/10/2012 9:25 am
I've used a Shimano double front mech (SLX) with 32, 34 and 36 front rings and it was fine.
I found 24/36 pretty perfect with 26" wheels.
I wouldn't change the whole chainset to go for a 2x set up though - just dump the outer ring and get narrow chainring bolts for the middle (or swap the big for a bash if you reckon you need it).
Posted : 30/10/2012 9:27 am
cheers clubber!
i'm moving the existing 2*9 onto a new bike (making it 3*9 again) and have the chance to get all shiny new 10 speed for the turner.
the bash guard is essential given how clumsy i am - too many holes in my legs already...
Posted : 30/10/2012 9:44 am
Dropping from a 38 to a 36 big ring will give you a gear that is a whole 2 inches smaller.
Which is not worth talking about.
What cassette are you running?
Posted : 30/10/2012 11:11 am
i'm going to get a 11-36 cassette so that's a lower a gear already than the 11-34 9-speed cassette. is 24*36 the same as 22*34 in terms of gearing? i've had a look at sheldon brown's website (which is pretty awesome!), but it doesn't have a 36 tooth 10 speed cassette yet. need to do some maths type stuff i think...
Posted : 30/10/2012 1:31 pm
It will actually give you a high gear of almost 5 inches lower with an 11 rear sprocket and 26 wheels .
