Shimano Tiagra Bear...
[Closed] Shimano Tiagra Bearings rear
[#3559482]
I need to replace the bearings in my rear wheel on the commute, it's done a years worth and there's a tiny amount of side-to-side movement so looks about time.
Are all Shimano bearings the same size? Any idea of quantity needed each side?
As it's on the way home I was going to attempt the local Halfords as I'd expect them to have bearings instock, I'm just writing out an FMEA so I don't have to go back in the morning.
Posted : 13/01/2012 9:59 am
9 x 1/4" per side.
BUT a little play alone does not mean you need new ones, do a service by all means but if the bearings don't feel rough then they'll prob be shiney and fine.
Posted : 13/01/2012 10:16 am
Thanks Al, I've not serviced a Shimano hub for about 15 years, I'm a little weary of doing it tbh, distant memories of not getting the cones tightened correctly...
Posted : 13/01/2012 10:50 am
they're easy.
(with the axle out) do one side up REALLY tight.
with the other side nipped up (cone against locknut), you should be able to tighten the nipped-pair just by turning the locknut.
when it feels right, tighten the nipped-pair*.
that'll do-yer.
(*a little trial and error will get you from 'good enough', to 'ooh that's lovely' - i challenge you to tell the difference from the saddle though... 🙂 )
Posted : 13/01/2012 11:57 am
Cone spanners,grease, cup of your favourite coffee and half an hour of your time.
Posted : 13/01/2012 12:06 pm
what awhiles said though tighten the DS first.
A teeny (almost imperceptible) amount of play is ideal - tightening the QR then takes up the slack.
Posted : 13/01/2012 12:09 pm
