Shimano STEPS - Spe...
[Closed] Shimano STEPS - Speed Issue
[#10083074]
Brought a 20inch wheel ebike (Orbea Katu-e 40 2017 ex-display) from Bath and I'm in Sheffield
First ride (Commute) and it looks like the speed on the STEPS computer is way faster than the actual speed I'm travelling. This means that the motor cuts off at about 10mph, as it thinks its doing 15mph. The distance was about 14km when I know its only 9km.
I've had a look at the manual and dealer manual and can't see anything on how to solve the problem. Anyone got any ideas?
Posted : 09/07/2018 11:51 am
Can you set the wheel circumference on the speedo?
Posted : 09/07/2018 11:53 am
Place another magnet or two on the rear spokes?
l.e. Nevermind, that wouldn't help here. You could relocate the speed sensor somewhere near the bottom of the motor, then add magnets to the chainguard, as this reddit post mentions:  https://www.reddit.com/r/ebikes/comments/7nc8u5/i_unlocked_manipulated_the_speed_limit_on_shimano/
Posted : 09/07/2018 12:06 pm
Doesn't look like you can set the wheel circumference on the computer?
Not looking at manipulating the speedo, just want it to show the correct speed at the moment, as I'm sure it must do on most other bikes.
Posted : 09/07/2018 12:37 pm
The wheel circumference is definitely configurable, just not user configurable (otherwise people would just circumvent the 25kph limit). This means a trip back to the dealer, at least.
Posted : 09/07/2018 12:48 pm
Steps you say?
Posted : 09/07/2018 7:13 pm
What happens if you take the magnet off the spokes?  Mrs BigJohn has got a Giant Dirt E and I'm tempted to find out.
Posted : 09/07/2018 7:53 pm
 geex
If you remove the wheel magnet on E8000 you'll get an error code on the display and the motor will need to  be turned off and back on again to reset
Posted : 09/07/2018 8:19 pm
