I've managed to round off the head on the resevoir cap bolt on my Saint brakes, anyone know where i can get some from?
Posted : 21/03/2011 4:27 pm
Which Saint levers do you have? Older M800 or newer M810?
Posted : 21/03/2011 4:33 pm
M810
Posted : 21/03/2011 4:45 pm
Only available from Shimano as a diaphragm and lid set, but you'll probably find they're the same size as those from a Hope lever, or you could just try your local engineering suppliers. M3x10 sounds about the right size.
Posted : 21/03/2011 8:19 pm
Picture?
Posted : 21/03/2011 8:23 pm
if theyre the same as they were Hope ones fit and are torx. any lbs worth its salt will have these.
http://www.chainreactioncycles.com/Models.aspx?ModelID=3265
should fit
Posted : 21/03/2011 8:32 pm
No where near 10mm long. M3 sounds about right though. Might check eBay or screwfix out.
Posted : 21/03/2011 9:07 pm
