As above, what's the best way to unstick a stuck piston on a shimano SLX brake?
Posted : 20/04/2011 4:42 pm
Bump, someone must know
Posted : 20/04/2011 5:27 pm
remove pads. push back and hold in the pad that is moving - I find a cone spanner thru the centre of the calliper works and something behind it to stop the non stuck piston moving - pump lever until stuck piston moves. clean around it and lube with mineral oil. Work in and out a few times.
If the piston won't move or the seal fails then the calliper is scrap as I don't think spares are available for shimano slx
Posted : 20/04/2011 5:30 pm
Ta very muchly, i'll give it a go.
Posted : 20/04/2011 5:35 pm
