Shimano SLX M675 10...
[Closed] Shimano SLX M675 10 Speed Double Chainset & Hope Bash Guard
[#5561852]
Does this..
[url= http://www.chainreactioncycles.com/shimano-slx-m675-10-speed-double-chainset/rp-prod83170 ]Shimano SLX M675 10 Speed Double Chainset[/url]
Work with this?
[url= http://www.hopetech.com/page.aspx?itemID=SPG345 ]Hope Bash Ring[/url]
Posted : 30/09/2013 9:28 pm
No, you would need a triple and then use the bash to replace the outer ring.
Posted : 30/09/2013 9:34 pm
So just [url= http://www.blackspire.com/Defender-104 ]this one[/url] then?
Already have the 2x10 with 38t, found the above on CRC but been sold out of the 38t for ages and can't find alternative
Posted : 30/09/2013 9:36 pm
Certainly looks like it would do the job, can't say I've ever seen a double specific bash before.
Having said that Hope do state
Our new aluminium bash ring takes the place of the large chain ring on single or double ring set-ups
so I could be wrong! 😳
Posted : 30/09/2013 9:41 pm
Hope probably had the older M665 double&bash design in mind when they said that. The newer 675 double has a different spider than doesn't lend itself to a bash (or indeed a 32t single ring), although Blackspire do seem to have created one.
Posted : 30/09/2013 9:53 pm
Xtr double is different its a triple with little removable outer tabs [url= http://www.chainreactioncycles.com/mobile/shimano-xtr-trail-m980-10-speed-double-chainset/rp-prod54864 ]Linky m980[/url] you take them off to add bash
Posted : 30/09/2013 10:10 pm
I saved myself a few quid and went for the M665. Double specific chainline, able to run a bash and steel pedal inserts make it a better crankset imho.
Posted : 01/10/2013 8:19 am
