Shimano shadow rear...
[Closed] Shimano shadow rear mech long or medium?
[#2179792]
only have medium in stock at CRC . Is that because most of us use a long?
I have searched for a mech length thread and cant find any advice on which to but.
Thanks
Posted : 11/11/2010 4:56 pm
It's based on the number of teeth difference between the biggest and smallest possible ratio's and thus how much 'slack' the mech has to take up at the extremes.
As a rule of thumb - if you're running a triple you need a long cage mech.
Posted : 11/11/2010 5:02 pm
thanks i will get a long
Posted : 11/11/2010 5:04 pm
Yeah, Shimano will say that if you run a triple then you need long cage. However if you never run big-big sprocket combinations then a medium will be fine. I run all my bikes with a medium cage and an 11-32 cassette and don't have any problems.
You don't need a long. The Shimano Shadow "medium" cage is very long- about the length of an old long mech. You only need the Shadow long (or rather "extra long" if you're running a 36T cassette out back with a triple of run big touring chainrings.
Posted : 11/11/2010 5:06 pm
ah, sorry OP, I didn't know that 🙁
Posted : 11/11/2010 5:10 pm
