Shimano pressfit bb...
[Closed] Shimano pressfit bb to GXP. Help please?
[#7679987]
Hi,
On a 2015 Giant Defy Advanced, what BB do I need to convert it from the Shimano press fit that is in there to a gxp type and can run a SRAM crankset?
Thanks all.
Stu.
Posted : 01/03/2016 10:37 am
Bump for the lunchtime crowd.
Posted : 01/03/2016 1:06 pm
There used to be a company (bright line components?) that made a top hat style alloy cup that sat inside the bearing, a bit like the Hope GXP adapters, but designed for Shimano BB's. No idea if they still exist.
I run a Hope one with the Hope adapters. Works fine.
Posted : 01/03/2016 5:26 pm
Thanks Hob Nob
Posted : 02/03/2016 2:53 pm
You may be able to use a top-hat bush to reduce the non-drive bearing side from 24 to 22mm on your HT2 BB - whether the Hope adaptor works is probably down to trial and error. Otherwise, simply fit a new GXP BB86
Posted : 02/03/2016 3:25 pm
