Shimano post to pos...
[Closed] Shimano post to post rear brake mount ?
[#6711629]
Hi All
So replacing my rear formula 180mm brake on a spicy 2012 with Shimano. The existing rear formula currently has a post to post mount.
I can't seem to find the equivalent shimano post to post rear mount.
So can i use the existing formula rear one? or do i need to get a front post to post in 180mm and use on rear?
Posted : 17/12/2014 9:29 am
They should be the same as post to post is pretty standard.
I've never had an issue using different ones in the past, maybe had to use a small washer as a spacer to move the brake out a little further but that's about it.
Posted : 17/12/2014 9:32 am
I recently changed my rear PM-PM from avid 185 to shim xt 180. Its the xtr adaptor labeled up as a front one, but worked perfectly fine on the rear.
Posted : 17/12/2014 10:17 am
