Shimano pads (squea...
[Closed] Shimano pads (squealy brake content)
[#432436]
Is having squealing/heavily vibrating hydraulic brakes (Shimano XT) a harbinger to the fact I need new pads, and are there any pads that are less likely to be noisy than others?
Posted : 29/03/2009 8:03 pm
Worn out pads normally make grinding and grating noises, squealing and vibrating is usually down to contamination(such as oil on the pads), glazing(dragging brakes on long descents?), or maybe a misaligned caliper/sticky piston(do both pads hit the disc dead square and at exactly the same time?).
Also worth checking all your bolts are tight too.
Posted : 29/03/2009 10:31 pm
Cheers coatesy, I suspect it may be glazing then as everything else seems in order, is there any cure for this apart from not being a sissy and using my brakes so much on long descents?
Posted : 30/03/2009 7:43 pm
