Shimano MT-400s
[Closed] Shimano MT-400s
[#11728676]
Thinking of picking these up: https://www.ebay.co.uk/itm/Shimano-MT400-Hydraulic-Disc-Brake-Set-1300-1000mm-J-Kit-Internal-Routing/193658032578?epid=4028056945&hash=item2d16eb11c2:g:PCIAAOSwAE9fW25g
and was wondering if anyone has had any experience with them?
Thanks
Posted : 01/02/2021 2:57 pm
Haven't run those but you can get Clarks M2 for the same money and they're pretty good and no reliability issues so far.
Posted : 01/02/2021 3:02 pm
@smokey_jo thanks ill have a look at those
Posted : 01/02/2021 3:20 pm
I've run an older pair of those budget shimano single piston stoppers for over a year.
I love 'em.
They don't have the servo wave of the deore+ brakes, which in turn makes them feel less on/off and you really do get more modulation and control. They feel much closer in feel to the hope 4 pots on my other bike than to other shimano brakes.
The levers are fairly long but I run them inside of the gear shifter for a perfect single finger position.
I run them with 200mm front and 180mm rear discs and would encourage you to do the same.
They are a bargain and haven't gone wrong.
Posted : 01/02/2021 3:30 pm
I made up a parts bin special just before Xmas and I'm using an older version of these brakes.
Apart from squeaky pads (which was to be expected as they had sat in a plastic bag for god knows how long) they have been spot on. They lack a bit of power compared to fancier brakes, my main bike uses XTs but if anything they are more consistent (zero wandering bite point).
Bear in mind this is based on a sample size of two though!
Posted : 01/02/2021 3:41 pm
OK thanks guys I will probably pull the trigger on these then.
Posted : 01/02/2021 4:24 pm
Have these on two boys' bikes (the adjustable reach makes them great for that) and they have been spot on.
Posted : 01/02/2021 4:48 pm
