shimano middle ring...
[Closed] shimano middle ring orientation
[#5089174]
got a new ring as mine is well and truly hooked now. pulled it apart without taking note of how it sat - so which way around does the new one need to go regards all the shaped shift ramps? does it even matter?
Posted : 22/04/2013 10:09 am
Yes!
Ramps on middle ring face the granny ring, or another way of checking is to make sure the writing/numbers stamped on the big ring face outwards, and on the middle and granny inwards, or towards the bottom bracket.
You know there is also an little tab that should be lined up with the crank?
Posted : 22/04/2013 10:18 am
If you fit it the wrong way round you will find the chain comes off breathtakingly easy as soon as you put a bit of pressure on the pedals 😳
If in doubt the ugly-looking side of the ring faces inwards
Posted : 22/04/2013 10:27 am
I realise that the ramps are on the inside haha - i meant the rotation of the ring, as the ramps are asymmetrical.
Posted : 22/04/2013 11:30 am
so which bit hole needs to align with the pin on the outer ring, if it matters
Posted : 22/04/2013 11:33 am
As I said, you align the small tab on the inside edge of the ring (at approx. five o'clock in your picture) with the crank.
Posted : 22/04/2013 11:36 am
As above the barely visible bit that looks like a mistake lines up with the crank arm
Posted : 22/04/2013 12:05 pm
ahh i see what you mean, gotcha. cheers chaps
Posted : 22/04/2013 12:54 pm
