Shimano M8120 Brake...
[Closed] Shimano M8120 Brake Hose
[#11196635]
Evening, hopefully this will be an easy question.
I need to know which brake hose my M8120’s have.
I’ve botched hose shortening and I’m going to need to buy a hose and olive set, but I don’t know whether I need 2.3mm (brass) or 2.1mm (SS) without taking it all apart again. The hose, helpfully, only says ‘Shimano High Power Hose’ on it. Afaik the Olive truly is universal... ?
Posted : 17/05/2020 9:11 pm
Bh90
Posted : 17/05/2020 9:13 pm
Ah. I think it’s BH90?
Posted : 17/05/2020 9:14 pm
Lol Simon wins fastest finger...
Thanks! 😀
 PJay
It's SM-BH90-SBM.
I tried to find out via Shimano what the difference was between SM-BH90-SBM & the SM-BH90-SB I had was and got the following answer:
I have checked in with our tech team on this and can confirm that there is a difference in the banjo between the SB and SBM that allows for greater heat dissipation.
If you are using the 2 piston caliper then either the SB or SBM hose will be suitable
If you are using the 4 piston caliper then please only use the SBM hose.
However this seems a little odd as some Shimano 4 pots use straight connections (so no banjo).
Posted : 18/05/2020 10:08 am
The OP isn't changing hose, just shortening, which is done at the lever end so the connection to the caliper is irrelevant.
Posted : 18/05/2020 10:15 am
 PJay
Fair enough but "...buy a hose and olive set" sounds like the whole caboodle.
Posted : 18/05/2020 10:18 am
Oh yeah, missed that bit, sorry 🙂
Posted : 18/05/2020 10:19 am
