Andy/Iainc,
I found a video on you tube and just followed it. A lot of brute force to get them off but much easier going back on...had the Cx bike out on a couple of long rides and no sign of stretching or baggyness. Still as tight as a drum.
^^^^ link ?
Iainc,
Not sure how to do that:-(. If you do a search on Yahoo and simply type in how to replace Shimano ergo lever hoods there is a few videos showing how to do it. Let me know how you get on:-)
no worries, will have a look this evening, thanks
got mine in front of me here, can't say I'm looking forward to installing them, what a mess.
Kimi,
Relax as really easy to install..do the brakes first then the gears as I found that easier...although my frame has internal cable routing...the brakes do require a lot of bleeding to work effectively but once done they are really powerful..
thanks, I don't have the frame to hang them on yet but I did shudder a bit on opening the box.. my first STI's too.
Thanks Andy... Sounds like it might be worth it... Have been riding on the hoods since fitting the brakes, and have to admit to beginning to get used to it, but would like to get back into the drops at some point
Thinking of getting some of these later in the year. Is there any way of knowing whether you're buying a set with baggy or non-baggy hood rubber?
Picked up my new Defy yesterday. The covers are definitely a bit tighter than the ones on my CDF...
Good to hear new hoods fixes the issue. Might just buy some rather than faff with sending them back etc...
(BTW someone is still searching on Yahoo??)
Nedraper,
Regarding your post as above unfortunately not as fine out the box....it's only after you've pulled back the hoods to bleed the brakes and re-fit them back over you notice the baggyness...its most annoying and only new ones will fix it....
cheers bikepimp - will you have to fit new hoods again next time you bleed the brakes?
Finally got around to changing mine today! Ordered them from SJS. Had various bits off for maintenance anyway, so threaded the brake caliper (with pads out) through the hood and put them on from the back of the lever.
Huge difference. Old ones looked 50% bigger comparing them side by side. Much more comfy now.
Good to hear Horatio. I think I am going to have to do the same, but will try and hold out until I change my bars for some flared drops as re-taping seems a bit of a hassle at the moment!
I have one baggy hood and one tight. Will attempt a bar tape bodge to shore up the baggy one.
Same here , must get around to fitting the new hoods from SJC .
