just got my new deore chainset and bb today with no instructions! it has 3 spacers with it i just dont know where they go? ive tryed 2 on the driveside and one non drive and the crank axel sticks about 1/2" out of the otherside?
this is the sizing of the on-one website:
BB Shell
68mm (axle length of 113mm for most cranks these days except for '03 and later LX which need a whopping 121mm axle, according to this).
any help?
cheers tom
68mm bb = 2 drive side and 1 non drive side
ive tryed that and there is only a tiny bit of axel sticking through? not even enough for that little nut thing to fasten on?
There are [url= http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Deore/SI_0093A/SI-0093A-001-ENG_v1_m56577569830667233.pdf ]other things on the internet[/url] than this site you know?
Oh and try hitting it fairly hard with a rubber mallet to make sure it's properly inserted
Second that. This could well be your problem. If you don't have a rubber mallet any heavy hammer-like object will do. Just make sure you put a bit of wood between said hammer and chainset.Oh and try hitting it fairly hard with a rubber mallet to make sure it's properly inserted
sorted it now i hope (fingers crossed) i was given 3x 2.5mm spacers and 1 one the drive side and one on the nondrive side works fine
cheers tom
