Shimano Dura Ace/10...
[Closed] Shimano Dura Ace/105 cassette difference
 Rip
[#721072]
I need a new cassette for my road bike. It's currently Dura Ace.
With there being a £90 difference in the cost of the 105 v the Dura Ace, what difference would I notice between the two?
Does the Dura Ace shift better/wear better/perform better?
Why would I want to spend the extra?
Posted : 20/07/2009 1:23 pm
Dura ace has some Ti cogs and its on a spider. Both made it lighter.
Dura ace will shift better, but both should last about the same.
Posted : 20/07/2009 1:28 pm
DuraAce is lighter but probably shift slicker & wear faster,.
DuraAce
Close ratio gearing allows a more efficient use of energy through finer cadence control
Largest sprockets are mounted on a lightweight alloy carrier to reduce weight and increase rigidity
4 largest sprockets are made from titanium to reduce weight without sacrificing strength
Sprockets are extensively cut away and drilled to further reduce weight without reducing rigidity
Nickel-plated finish offers hard wearing resistance to corrosion
Alloy cassette lockring
For Super Narrow 10-speed HG chains
Weight: 163 grams for 11-23 tooth
105
Hyperglide sprockets have a computer designed tooth configuration with contoured shift gates, resulting in a crisp smooth shift even under load.
- Close ratio gearing allows a more efficient use of energy through finer cadence control.
- Largest sprockets are mounted on a lightweight alloy carrier to reduce weight and increase rigidity.
- Sprockets are cut away and drilled to further reduce weight without reducing rigidity.
- Nickel-plated finish offers hard wearing resistance to corrosion.
- Pearl-bright steel cassette lockring.
- For Super Narrow 10-speed HG chains.
- Light alloy sprocket carrier is used to mount the lowest sprockets to reduce weight and increase rigidity.
- Larger sprockets are drilled out for further weight reduction.
- Average weight 219 g for 11 - 23T.
Posted : 20/07/2009 1:30 pm
 Rip
Thanks for the help. I'll go with the 105!
Posted : 20/07/2009 1:47 pm
