Shimano Deore M618 ...
[Closed] Shimano Deore M618 Freehub body - too much play
[#10532925]
As the title really, I've got an M618 freehub body and it's a bit loose. I've only ever messed with cup and cones for the outer bearings so not sure how to adjust the freehub? It's a through-axle hub if that makes a difference
Posted : 14/03/2019 11:56 am
If it's got play in it then it will need replacing.
Posted : 14/03/2019 11:59 am
Looks like the replacement part # from Madison is 3TL 9804 (£39.99)
Posted : 14/03/2019 12:00 pm
Oh, how annoying. Thanks for the help though!
Posted : 14/03/2019 12:11 pm
I think you can remove one or two "bearing adjustment washers":
Posted : 14/03/2019 12:16 pm
Ah, interesting, thanks. Worth a look.
Now, how do I remove the freehub body? Obviously being a 12mm rear it isn't the usual allen key job.
Posted : 14/03/2019 8:44 pm
