Shimano Deore M615 ...
[Closed] Shimano Deore M615 brakes
[#7526651]
Hello,
Does anyone know if Shimano Deore M615 brakes are compatible with Sram Guide R centreline 200mm callipers?
Posted : 18/12/2015 6:26 pm
Do you mean rotors? Yes they are, as long as you use a 200mm mount.
Posted : 18/12/2015 7:15 pm
Sorry, yes rotors. Thanks, do you think I can use my existing mount?
Posted : 18/12/2015 7:21 pm
I seem to remember that (many moons ago) a front mount fitted to the rear required the rear rotor to be 20mm smaller ie a 180mm front mount on the back worked with a 160mm rotor. It may have changed though like I say it was a long time ago
Posted : 18/12/2015 7:24 pm
 cp
What size is your existing rotor?
Posted : 18/12/2015 8:09 pm
200mm..
Posted : 18/12/2015 8:10 pm
If you're taking brakes off and replacing them with the Deores, leaving the rotors the same then yes you can. What works right now will also work if you swap just the brakes to Deore
Posted : 18/12/2015 8:21 pm
Yeah sorry misunderstood you if you are using those rotors currently when you swap the brakes just leave the mounts inplace when fitting new ones
Posted : 18/12/2015 8:28 pm
I'll get them ordered, cheers for your help
Posted : 18/12/2015 11:27 pm
