Shimano clipless pe...
[Closed] Shimano clipless pedals question - destruction content
 piha
[#3033802]
I have a pedal (PD M770) stuck on a crank arm and I want to drill through the spindle so I can get it off the crank. I have tried using a HSS and a colbalt drill bit but I'm not getting anywhere. Any tips or ideas?
Thanks in advance.
Posted : 10/08/2011 9:25 am
 piha
Anyone? 🙂
Posted : 10/08/2011 1:05 pm
dismantle the rest of the pedal - clamp it in a vice and turn the crank....
stupid stupid question but your going the right way yes ?
Posted : 10/08/2011 1:06 pm
You were trying to turn it the right way, right?
EDIT: beaten to it.
Posted : 10/08/2011 1:07 pm
Rather than drill the spindle, why not disassemble the pedal from the outboard end and put the bare axle in a vice?
EDIT: Doh too slow.
I'd try heating the pedal axle before I resorted to drilling AND MAKE SURE I WAS TURNING IT THE RIGHT WAY. 😯
Edit: Must type faster.
Posted : 10/08/2011 1:08 pm
 piha
When originally trying to remove the pedal I was definitely turning the allen key in the correct direction. Where the allen key fits into the pedal have become rounded and the metal has split. I have dismantled the pedal but don't have access to a bench vice, hence why I've been trying to drill it out. Time to head to a local engineering shop me thinks.
Cheers folks.
Posted : 10/08/2011 1:23 pm
if the allen key hole has rounded, use a pedal spanner on the flats on the other side.
Posted : 10/08/2011 1:24 pm
what about... a spanner? or can one no longer use them on shimano pedals?
Posted : 10/08/2011 1:26 pm
No spanner flats on XT or XTR (and possibly more)
Posted : 10/08/2011 1:57 pm
Nor M540s, which are just XTs, without the XT moniker and a lower price tag.
Posted : 10/08/2011 2:41 pm
not tried this on a pedal, but i once got a 40cm masonry drill bit well and truly stuck in a wall. I managed to get it out by grinding 2 flat areas with a dremel on the part the drill chuck fits on, then using a spanner on these.
If you've got access to a dremel or something similar you could try that?
Posted : 10/08/2011 3:16 pm
Spindles aren't thick enough to grind usable flats onto IME, vice is the best shout.
Posted : 10/08/2011 3:18 pm
Are the cranks worth it?
How about grinding/cutting the axle off, removing (slotting more and collapsing if nec) what's left? (8mm AK & therefore not too much metal left?
Posted : 10/08/2011 3:23 pm
