I have Shimano SM-RT81 160mm disc rotors on my wheels and want to run a spare set of wheels so need some new disc rotor to make the swap over real quick. Cassette is already sorted.
Anyone know if Shimano SM-RT10S rotors will be ok?
They're a lot cheaper than the RT81's which is a good thing as i'm on a budget and the spare wheels won't get used that much.
Cheers!
Posted : 11/04/2019 9:14 pm
They'll work as long as you're using resin pads. Heat dissipation won't be as good so may fade depending on how you brake.
Posted : 11/04/2019 9:18 pm
Nice one thanks, I'll give them a go. Pretty sure I have resin pads.
Posted : 11/04/2019 9:40 pm
