Shimano Brakes with...
[Closed] Shimano Brakes with Hope Discs
[#4738322]
Hi Guys,
Is anyone running the new shimano, (xtr,xt,slx) brakes but with HOPE FLOATING discs?
IS the braking surface, (disc depth, width etc) OK and match/work well?
I know I have to have the same size dia but not sure on the rest as I don't have any to hand to measure.
Thanks.
Posted : 11/01/2013 11:32 am
I think they are fine, brake area is very similar sized.
Question has been asked before on here so search would probably tell you more.
Posted : 11/01/2013 11:35 am
 D0NK
I had a hope floating disc where the rivets fouled the shimano calliper, was told you could file the calliper down a little but I just switched rotors. few years ago, calliper/rotor design may have changed slightly since then.
Posted : 11/01/2013 11:37 am
Shimano deores with saw tooth working sweet here if it helps
Posted : 11/01/2013 11:46 am
Yes..
No dramas here either..
Floating + XT, and Floating + SLX
Posted : 11/01/2013 11:50 am
Thanks Guys,
Yeah did a couple of searchs but it nearly all for sale stuff.
Donk, yeah I did hear that with some old brakes, why i am double checking.
Banks, thanks for the info, but really after the xt/slx brakes with the new pad shape. (been a pain I know!)
Posted : 11/01/2013 11:52 am
Thanks Surger, 😉
Just what I am after, out of intrest did you ever try the Ice discs and was there much diffence if you did?
Posted : 11/01/2013 11:58 am
