Shimano brakes on F...
[Closed] Shimano brakes on Fox post mount.
[#416347]
Hi,
can I stick a Shimano XT caliper directly onto a Float post mount or do I need an adaptor?
Also, how easy is it to get the caliper aligned properly (piece of piss with an IS mount and adaptor)
Cheers,
SC
Posted : 23/03/2009 11:36 pm
is it a post mount caliper? is it the right size disc for the fork mount?
and its much easier to align a post mount caliper than a IS.
Posted : 23/03/2009 11:38 pm
Hmmm...
Questions, questions.
To be honest Jambo, I'm a bit ignorant about these things. They appear to be post mount calipers which are bolted onto IS adaptors. I kind of assumed that I could just remove them from the adaptors and stick them straight on a post mount.
Currently using 160mm disc and I can find PM to PM adaptors for 185 and 203 rotors so I assumed (again) that 160mm is the default size for post mount.
Posted : 23/03/2009 11:44 pm
depends on the fork. my totems are 203mm disc with no adaptor.
suck it and see. if its not far enough out then you need an adaptor. there only about a fiver.
Posted : 23/03/2009 11:48 pm
Cheers.
I've just found the tech. PDFs on the Shimano site - looks like it'll just go straight on the PM without an adaptor. Sorted!
Posted : 23/03/2009 11:50 pm
