Shimano brake quest...
[Closed] Shimano brake question
[#1928371]
can you use this type of hose connector with SLX brakes?
Mine had the straight fitting originally, but the 90 degree jobby would making routing the cable a lot easier.
Posted : 24/08/2010 8:55 pm
Nope, the banjo fitting won't work with an SLX caliper.
Posted : 24/08/2010 8:59 pm
Aw that's a pain in the sac.
Is there an aftermarket hose which can do a 90 degree mounting like that on SLX brakes ??
Posted : 24/08/2010 9:12 pm
Cheeky bump for the morning crew 🙂
Posted : 26/08/2010 9:55 am
You could try emailing Jagwire Europe jageurope@nowcompany.com
to see if they have a LBS stockist - they have reasonable priced mix and match sets of banjos.
Posted : 26/08/2010 10:09 am
