Where can you buy the little nuts that hold the hydraulic brake hose into the top of shimano brake calipers (Shroud nuts)? CRC are out of stock...
Please point me in the right direction, I do not live near a bike shop...
Anyone...?
I've found 2 for you, but this will leave you 2 short.
Anyone else help this poor fellow?
I should have some. drop me a line.
Many thanks to bigyinn! As he said just 2 more to go...
bikewhisperer, YES PLEASE...! However, I can't see your email in your profile, mine is visible, can you email me or post your address?
Thank you...
oops.. email wasn't set. YGM!
Many thanks to bigyinn and bikewhisperer!!!
I'm in a similar position. Building up my new Scandal 29er with some parts off of my old 456. Forgot it had brake hoses threaded 'through' the guides, so had to cut the end off. As I pulled hose through, it whipped and the shroud nut disappeared into the depths of the (ashamedly untidy) garage to never be seen again! I've got a spare olive & insert but the only place selling the nut seems to be CRC, & they're still out of stock. Any ideas where to get one? Ta!
