Shimano brake lever...
[Closed] Shimano brake levers - adding reach adjuster?
 a11y
[#5713916]
How easy/cheap/expensive is it to add the reach adjuster (as found on SLX/XT brakes) to my Zee brake levers which require adjustment via allen key?
Not essential, but it'd be great to have tool-free adjustment on my Zees.
(I've already searched online but I must be looking for the wrong thing as no results answered this question)
XT lever:
Zee lever:
Posted : 22/11/2013 2:42 pm
You could (possibly) replace the blades with this part (and the right-handed equivalent), but probably not that much cheaper than new XT Levers.
Shimano don't list the adjuster separately, it's part of the blade unit.
http://www.petracycles.co.uk/shimano-spares-blm785-lever-unit-left-p-89920.html
Posted : 22/11/2013 2:51 pm
Yes you could pop the XT lever blades into the Zee body (I have done it as an emergency repair job). But at £24.99 per lever blade you are better off just buying complete levers.
Posted : 22/11/2013 3:08 pm
These guys are VERY cheap for levers
http://www.eu-bikeshop.com/i17589/42065-42066-new-shimano-deore-xt-bl-m785-brake-lever-left-right-silver/
Posted : 22/11/2013 3:09 pm
 a11y
Ah, cheers folks. Just not worth the cost unless I can find some knackered SLX/XT levers and cannibalise them for bits.
Posted : 22/11/2013 3:39 pm
http://huckingkitty.com/node/9
Posted : 22/11/2013 3:47 pm
Im not trolling, surely you only adjust your lever the once and thats it? If its got reach adjustment by allen key isnt that enough? I cant say Ive touched mine beyond the initial, "ooh whats that knob do?".
Posted : 22/11/2013 4:01 pm
@bigyin +1
Never touched mine since the initial installation, because - surprise - my hands are still the same size!
Posted : 22/11/2013 4:09 pm
bigyinn - Member
I asked the same last time something like this popped up and got vague answers about cycling on the top of Everest or something.
Posted : 22/11/2013 4:29 pm
 a11y
No, serious question.
I've yet to experience it with the Zee's, but I was frequently needing to adjust the reach on my Formula RX as the pads wore. It got bloody annoying out in the Alps during the summer when I was going through a set of (admittedly soft) pads per day. It was an utter PITA needing to reach for the allen key, adjust it a bit, then adjust it a bit more.
I guess brakes shouldn't need this constant level of adjustment then?
Posted : 22/11/2013 4:36 pm
I've never had to adjust the reach on any hydraulic brake. What I have done is over-filled them so that very little lever travel is necessary. That's just how I like the set up.
Posted : 22/11/2013 8:07 pm
a11y - Member
I get that from time to time too, but usually a sign there's a bleed needed or are leaking fluid.
Posted : 22/11/2013 8:09 pm
I can only assume that a11y has his lever closer to the bars, so as the pads wear the lever pulls to the bars and has to adjust it outwards a bit?
Posted : 23/11/2013 10:52 am
 a11y
Fairly close, but yes basically when I put in new pads I need to adjust them outwards to counteract the change in bite point. They feel perfectly firm and powerful, no evidence of fluid leak that I can see.
Back on this topic, I guess adding adjusters to my Zees is a non-starter for me. Hopefullly not required.
Posted : 23/11/2013 7:50 pm
We ignoring the how to above?
Posted : 23/11/2013 8:25 pm
