Shimano brake calip...
[Closed] Shimano brake caliper question.
[#9998059]
Hello.
Any reason I can't run an older XT or XTR hydraulic caliper with a newer Ultegra Di2/hydraulic lever?
Ultegra caliper has died and I always had to buy special pads for that one caliper, the TRP on the rear uses the same as the wife's Deore brakes and it would be better if I could replace with something which uses the same kind.
Posted : 20/05/2018 8:55 pm
PS. If I can are the caliper fittings the same? The screw on the end of the Ultegra's hose looks the same as the ones on the Deores.
Posted : 20/05/2018 8:58 pm
No-one tried this then?
Posted : 21/05/2018 2:25 pm
