Shimano brake bleed...
[Closed] Shimano brake bleed kit
[#4712852]
I have an original, ie old (2009?), SLX disc brake set up on my bike and want to bleed it. Can anyone recommend a bleed kit off ebay which they've had success with?
Posted : 04/01/2013 3:27 pm
Try epicbleedsolutions.co.uk
Posted : 04/01/2013 3:30 pm
epicbleedsolutions but as it doesn't need a cup thing for the reservoir then just get a 50ml syringe and some aquarium air stone tube from a pet shop.
Posted : 04/01/2013 4:16 pm
I would agree with the others on epicbleedsolutions.co.uk I used a couple of syringes from ebay and a short piece of PVC tubing from B&Q. Personally I would recommend using a toe clip strap or similar to hold the lever in place - frees your hands up.
There are lots of videos on Youtube showing you how to bleed. I recommend this one:
The only problem you might have is if you've lost all the fluid and have then squeezed the lever a lot. This results in thousands of tiny bubbles which can take several bleeds to get them all out - lever will go rock hard when you've fully bled the system.
http://www.chainreactioncycles.com/Models.aspx?ModelID=29899&utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom
Just as good as Shimano and half the price. Just as good as Shimano only it's green rather than pink (just in case you have transparent hoses)
Posted : 04/01/2013 8:57 pm
Don't be soft getting bike specific mineral oil, LHM oil is the same stuff
Eg http://www.ebay.co.uk/itm/320846598309?redirect=mobile
Posted : 04/01/2013 9:04 pm
epicbleedsolutions.co.uk also here, worked perfectly and cheap.
[quote> http://www.chainreactioncycles.com/Models.aspx?ModelID=29899&utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom
Not sure how this is 1/2 the price, it's £4.99 (£39.92/l) for 125ml ( when the proper Shimano oil is £16.99 for 1l from CRC.
Posted : 04/01/2013 9:05 pm
Epic kit is spot on- you can easily make your own tbh but it just comes down to how you value your time.
Posted : 04/01/2013 9:06 pm
That's true. However, for most people will never need anywhere near a litre of mineral fluid. Mineral fluid isn't hydroscopic (unlike dot fluid) so you only need to bleed when you crash into a tree or pop the pistons out when you've got the bike in the car.
That said I am the only one of my group of mates who ever has a bleed kit. Could be worth getting a litre if you're likely to be fixing your mates bikes as well.
Posted : 04/01/2013 9:17 pm
