can i remove the indicator and fir a blank ?
im wanting to run the gear shifter inside the brake lever.
i donr this recently on a xt gear pod and it cam with a blanking plate.
does anyone know if the alfine can be run this way and if a blanking plate can be fitted from other model shifters?
thanks tam
exploded digram of shifter and indicator top right on this sheet
http://techdocs.shimano.com/media/techdocs/
content/cycle/SI/Alfine/SL-S500L/SI_6MM0A_En_v1_m56577569830655811.pdf
Posted : 01/07/2009 11:58 am
Posted : 01/07/2009 11:59 am
