Don't know if anyone's here's got the 'inside track' on shimanos plans, but from a quick look on the Crc website i found some disc brake levers that are neither left nor right specific. I believe that the term is 'flip-flop'.
Will this be part of a general trend in the future?
Certainly something I'd welcome, should I be hiring a bike in the alps.
Here's the linky
http://www.chainreactioncycles.com/mobile/shimano-deore-m575-disc-brakes/rp-prod87344
They're some vintage ones, at least 2 generations old (I think m596, m615 and maybe one more since then).
I can't see them switching back to 'flip-flop' ones.
As above, they're old.
I can't see them going back to flip flop either - more weight, more restrictive design etc...
First review is from 2013 which probably tells you all you need to know in regards to their age.
They weren't the only 'any way up' levers about, but they offered little benefit to riders, I mean how many times do you need to switch? It was more about cost savings a single lever to design and make rather than two.
The shop will (or should) ask you what your preference is when you hire it, then will swap the hoses if needs be.
It's a solution to a problem that doesn't exist for riders, just saves a few bob in production.
Some manufacturers still send bikes out to the UK with European style brakes. Not the end of the world but it does annoy mechanics a bit.
aaah...didn't spot the review date!
Thanks for the input, folks:)
Much appreciated.
