shimano 2012 brakes
[Closed] shimano 2012 brakes
[#5640763]
Any one know if I can swap levers on them have a broken xt unit and a zee lever I can swap over or is it impossible
Posted : 27/10/2013 11:07 pm
Theyre basically the same
Posted : 27/10/2013 11:13 pm
its the actual blade I want to swap.
Posted : 27/10/2013 11:34 pm
Why not just buy a replacement [url= http://www.madison.co.uk/products/cycling/transmission-braking-components/brake-levers/bl-m785-lever-unit-left/ ]XT lever [/url]@£24.99 link is for the LH
The Zee & XT look to have the same interface, but you loose the adjustment knob going from the XT to Zee
Posted : 27/10/2013 11:49 pm
cheers, ill have a play I have a broke xt and zee so rather make one working brake if i can. cheers for link though if or when i kill both its cheap as chips to replace lot
Posted : 28/10/2013 12:07 am
