Shimano 10spd rear ...
[Closed] Shimano 10spd rear mech - what's best for an 11-42 expanded cassette?
[#7775837]
I suspect I'll need to replace the rear mech soon so it makes sense to get one that works as well as possible with my current set-up (XT 11-36 with a Wolf 42t expander).
Is there a standout mech I should be going for, or is it just a case of crunching the specs and buying a longer B adjustment screw?
Posted : 18/04/2016 4:03 pm
I think you need to budget for a Rad cage to get the best result. You'd have thought there'd be some second hand bargains as others go 11 speed
Posted : 18/04/2016 4:06 pm
Think GS/SGS Shimano mechs are much or a muchness when it comes to 42t, some frames will require extremes of B-screw adjustment, some won't.
I'd get a cheap one and use the spare cash on a OneUp Rad cage, when I has running 1x10 the Rad case moved it frpm "just OK" to "shifting perfectly".
Posted : 18/04/2016 4:08 pm
What I found is, with a medium cage XT I got it working fine but it was a pain, and had little margin for error- it went sloppy during muddy rides and if the mech got bumped it all went wrong. With the radcage, it's much easier to set up, and more reliable/less picky. if I was building a 1x10 today I'd definitely use a radcage or maybe the goatlink.
TBH once you start with all these costs, the cost argument can stop making much sense.
Posted : 18/04/2016 4:09 pm
Maybe an XT 11 speed mech if it works as suggested in this thread
[url= http://singletrackworld.com/forum/topic/can-i-use-a-11-speed-derailleur-with-a-10-speed-shifter-and-cassette#post-7647138 ]http://singletrackworld.com/forum/topic/can-i-use-a-11-speed-derailleur-with-a-10-speed-shifter-and-cassette#post-7647138[/url]
Posted : 18/04/2016 5:29 pm
Yeah... May just end up going 11. 🙂
Posted : 19/04/2016 9:58 am
I just used a long cage 10 speed shimano shadow plus mech and a longer B screw.
Posted : 19/04/2016 10:15 am
Ordinary XT long cage mech here with my Sunrace 11-42 cassette, albeit with the B screw wound in as far as it'll go.
Shifting quality is excellent - indistinguishable from the stock 11-36 setup.
I am planning on going 11 speed, but only when the 11-46 cassette makes an appearance.
Posted : 19/04/2016 10:16 am
Zee with radr cage worked superbly for me.
Posted : 19/04/2016 3:20 pm
+1
Posted : 19/04/2016 3:35 pm
Thanks all. Seems a radr cage is the short-term fix, which is also cheaper than a new rear mech - win!
Posted : 19/04/2016 3:58 pm
