Just got a new road bike and it has a 105 derailleur. I want to get a wider range cassette but not sure if I have the short or medium cage. It has some numbers on it 5701 but nothing to state cage length. How do can I find this out?
look up a picture of both, one will be noticeable longer than the other
example:
should be enough to know which one you have
what size cassette do you want anyway? I thought shimano short cage could handle 30? or am I wrong
Was wanting a 32 but from what I read online the short will do 30 but is all very confusing compared to mtb stuff.
5701 is an up-specced mech that should handle a 32t cassette. ( read elsewhere a while back when researching for myself.).
Obviously you will need to check that the arm can handle the chain length difference across the range of the cassette and rings.
I have compact setup CX bike with a 5701. It's running a 28t just now, but I can put a wheel with a 32t on it to check if you want.
I believe shimano's new media can cope with 30t sprocket Max ...
what size are your chainrings?
I have a 34 inner and 11-28 cassette and it's got me up everything so far (including 500m of 10-15% gradient), and I'm definitely not hardcore
if you're on compact rings a 30t cassette should handle anything you can throw at it
Right, pretty sure it's a short (going by pics) Got a 50/34 so think I might just get a 30T and throw it on and see what happens.[b]Fisha[/b] would be cool if you could through on the 32T cheers.
Ok, I'll fit it tomorrow first thing and post back.
11-23 will get you up anything 😉
[b]Haze[/b] yeah right!
Nice one [b]fisha[/b] Thanks for taking the time to try this for me. Much appreciated.
