Fit some zee rd in other half bike with narrow wide and slx ispec-b shifter, everytime I turn on the clutch the shifting and pedalling become a bit stiff (ish) than normal.. If I turn it off it all go silky smooth.. I have only tried it in the workstand though.
I have an XT med shadow+ even clutch on/clutch off there is no difference in shifting or pedalling thingy in the workstand or in the trail.. If anybody can shed light on this, i would be really grateful. Many thanks.
Checked the B screw?
Clutch off would be slack enough maybe for it not to have an impact.
Don't know, but I've found when setting up gears if the shifting and pedalling is a bit stiff, often fiddling with the B screw makes it better, and I've noticed this more with my X9 Type 2 clutch. Though SRAM clutch is different in that it's really just always on, or at least you can't turn it on or off manually.
Fiddled with b-screw as well but has no effect.. The stiff part is only the last 3 biggest cog where it is noticeable enough in the workstand.. However if I shift it back down and up again..it goes back to normal and no stiff thingy... Only when i shift from smallest cog to biggest cog in 1 go (step by step increment)
Ahhh.. Fixed it..
In case anyone have this issue its the friction band.
http://bikefat.com/tech-how-to-adjust-the-shimano-shadow-plus-rear-derailleur-clutch/
Everyday is a school day 🙂
