If I have a 10 speed shifter I should expect 9 clicks in the lever, correct?
Just bought an SLX 10 speed shifter (SL- M660) from ebay and it only clicks 8 times. This to me says it's a 9 speed?
I don't need to mount the shifter with rear mech etc to prove this do I?
It might help to put a cable in it and put it under tension, but you're right about the number of clicks
Yeah, if its at one end or the other, a 9 speed shifter would be able to shift 8 times.
a 10 speed shifter would be able to shift 9 times and so on.
afaik, slx m660 was available in 9 and ten speed versions, although I could be wrong of course.
There was a 9 and 10spd M660 shifter. Sounds like you have the 9 speed one.
Thanks, yeah sounds like I got the 9 speed version
Has it got a little dynasys 'D'Â on it?
No Dyna-sys label on them. Just Shimano SLX
