Shavin' The Tu...
[Closed] Shavin' The Tube...
[#3962416]
Hi just a quick question...
Got a new frame, gunna put a cups in the headtube. Should the headtube the shaved before the cups go in or doesn't it matter?
What is the reason for shaving the headtubes?
Posted : 10/05/2012 7:35 pm
Yes but use an old school razor only.
Posted : 10/05/2012 7:40 pm
facing - make sure the ends are totally flat and parallel
reaming - taking out some material from the inside diameter if it's too tight or full of rough bits/warf etc (v rarely done on headtubes ?)
neither generally necessaary IMO
(must admit, opened the thread with some trpidation 😯 )
Posted : 10/05/2012 7:42 pm
and a dab of after shave
Posted : 10/05/2012 7:43 pm
shaved = faced
makes the faces at the end of the tube parallel which means the bearings will be aligned and will last longer.
I've never bothered.
veet or epilator
Posted : 10/05/2012 7:44 pm
[u]DO NOT [/u]use Veet near carbon 😉
Posted : 11/05/2012 12:26 pm
