Share your rockshox...
[Closed] Share your rockshox dual air +ve & -ve settings (and weight) please 🙂
75/70ish I am 71 kg
i weighed myself today and i'm a shade over 71kg Was probably running way too high a pressure at 100 then!
It's hard to set up forks when the trails are so damn muddy, what i need is some dry dusty Calafornian trails….one can dream.
Posted : 04/02/2014 11:25 pm
Running them that soft will make them plush but if your riding involves steep drops onto fireroads etc you may find yourself flat on your face, spitting out teeth....
Only saying, like..
Posted : 04/02/2014 11:35 pm
Right, i've had a chance to get out on them now and reckon i've got them set up pretty well, So i can now add my own setup to the list.
72kg/11.3 stone
85 +ve
65 -ve
rebound half way and then a couple of clicks towards the rabbit
I've set them up so they use all the travel and don't dive too easily under braking, mainly by running 20psi less in the -ve chamber (they "equalised" as per Northwind's post at 80+/ 70-) and messing with the compression.
They're plush! I might put a bit more air in the positive chamber yet, maybe go to 90+/ 70- but i haven't had any problems with fork dive or bottoming out so far. Very pleased.
Posted : 26/02/2014 12:37 am
Page 2 / 2
