As above, what's best?
*recalls the 'SFN jammed in SID carbon steerer and, btw, I weigh 18 stone' troll from days of yore*
Not an SFN is the answer.
Vaguely remember that!
Head Dr it is!
make sure you have a 5mm headset spacer above the stem too so that the stem clamps properly on the seerer.
And not to breath too heavily on the head dr bolt or it'll snap
Check the diameter as well. My flash KCNC bung wouldn't fit in my on-one mono carbons but a £3 FSA one from CRC did.
Will do, thanks
+1 Hed Dr was too fat for my carbon steerers. Had to use a dedicated roadie one (FSA I think)
+1 for checking internal diameter. A large portion of my Sunday was spent swearing at one.
Hed doctor every time. SFN can create an internal groove which can act as a crack propagation site.
Would the manufacturers of the carbon fork not tell you if you can't use the normal method ( an SFN) ?
[i]Would the manufacturers of the carbon fork not tell you if you can't use the normal method ( an SFN) ?[/i]
If they had any sense, they would...
most of them do - infact ive yet to see one that didnt .....
sad fact is most folk dont bother reading instructions and think they know best.
