Servicing/replacing...
[Closed] Servicing/replacing bearings - Royce Ti BB - How?
[#791330]
There's a bit of play and some creaking, so I assume the bearings have gone. How do I replace them?
ANyone?
Cheers.
Posted : 17/08/2009 12:09 pm
The bearings are just a press fit on the axle, but they can get stuck in the cups. Use a bearing puller to make life easy for you. If the bearings end up in the cups, then drive them out with a drift, being careful to swop from one side to another so you don't damage the cup.
Posted : 17/08/2009 12:52 pm
 mt
Phone Royce if you have any problems/doubts as Cliff(?) is the most helpful chap.
Posted : 17/08/2009 3:09 pm
It's a fairly easy job. Like TrevorB says, a bit of carefully thought out hammering normally does the trick 😀
Posted : 17/08/2009 4:10 pm
