Servicing Superstar...
[Closed] Servicing Superstar pedals?
[#1578774]
Hi just wondering if anyone has serviced their pedals and how to go about it? There's a nasty creak which I think is coming from them. Tried taking them apart but didn't get very far as I am a numpty.
Posted : 06/05/2010 9:59 am
I think a hammer or a rock is required.....
Posted : 06/05/2010 10:02 am
Never tried, mine have been fine for over a year.
But they will probably be the same as any other pedal, just take the end cap off, remove the nut and they should come apart. I guess there sealed bearings, so just replace them as required and put a little grease in there.
Posted : 06/05/2010 10:10 am
have you contacted them directly I have there customer service is absolutely fantastic in dealing with this sort of issue....did you really expect a serious answer like anyone would admit to buying them ...points and laughs
Posted : 06/05/2010 10:39 am
 GW
what pedals do you run Junkyard?
Posted : 06/05/2010 10:41 am
@davidtaylforth - ta will give it another go.
Yeah, thanks Junkyard 👿
Posted : 06/05/2010 10:42 am
Time ones as I like the float - I use platforms ...worse I have riser bars with ergo grips and bar ends as well. None of the wheels on my 3 bikes match shall I go on for you or do you have enough amunition to abuse me? Awaits the flames- Grum knows I was joking actually it reminded me to go buy some stuff from their website.
Posted : 06/05/2010 11:13 am
