servicing manitou b...
[Closed] servicing manitou blacks
[#1973330]
I have a pair of from 2003 (i think), spring one side and compression rod the other. The problem is that I am getting hydrolic lockout, i have striped them twice and followed the manual (which is crap). I put 50ml of oil in both sides, in the lowers when they are half on. when put back together they only have 2" teavel then they lock. I got no compression damping or lockout.
So any ideas, apart from the bin
Posted : 09/09/2010 8:59 am
Are you meant to put 50ml of oil into the lowers or are you guessing this might help?
Posted : 09/09/2010 9:45 am
This might help.
http://www.manitoumtb.com/manual_download.php?f=2003%20Black%20Owners%20Manual.pdf&t=Manuals
They're micro-lube and thus grease based AFAIR.
Posted : 09/09/2010 10:04 am
on the right side there is a adjuster for the compression damping into lockout and thats not working.
Think i may give up, back to my reliable marzocchi mx comps. i just wanted a bit more travel
Posted : 09/09/2010 11:18 am
