Servicing CK Hubs
[Closed] Servicing CK Hubs
[#1786408]
Has anyone bought the CK hub tool, is it necessary to keep these beauties running sweet, or am I better off spending the cash on servicing at my LBS? I've got Hope hubs in most of my wheels which I service with ease, but these things are a whole new challenge!
Posted : 10/07/2010 7:22 am
You don't need the tool for a quick service. Just a couple of 5mm hex keys will do it. You're better off with CK ringdrive lube to do it properly.
It takes about 10 minutes to do a rear; lots of step by step vids and manuals on the CK website.
There's little to go wrong if you're not pulling the bearings out, so you might as well have a crack.
Posted : 10/07/2010 7:49 am
Thanks ScottChegg - freewheel grabbed a little this morning so I'll get some of the CK lube and give it some TLC.
Posted : 10/07/2010 3:50 pm
If the freehub is dragging, its probably the the needle roller bearing in the freehub body needing a service, and that job is easier with the tools.
Posted : 10/07/2010 5:22 pm
