sending gpx file to...
[Closed] sending gpx file to Garmin edge - Alternatives to Garmin connect?
[#5964591]
That's pretty much it.
Presumably everyone else is using Garminconnect for today's sunny Sunday bike ride, and it's slow as hell.
Will any other site do the same? I'm not having a lot of luck. bikehike seems to be waiting for a response from the garmin site too. Is it going to be the same everywhere?
It needs to be a special garmin file type, doesn't it? Does tcx work?
Posted : 16/02/2014 10:32 am
I just drop the GPX file in the folder using windows explorer.
Posted : 16/02/2014 10:33 am
I much prefer ridewithgps for creating routes, so I export as a TCX and copy the file to the Garmin manually.
Posted : 16/02/2014 10:42 am
Thanks! So if I can save it as a tcx file in bikehike, i can drag and drop it into the "courses" folder in Windows Explorer?
Posted : 16/02/2014 10:44 am
Yes, but It needs to go into "new files". Then turn the Garmin on and it will recognise it and put it into "courses" itself.
Posted : 16/02/2014 10:46 am
no. apparently not. doesn't show up in courses when I disconnect and turn on the Edge
Ridewithgps keeps falling over when I try to upload manually, same as Garmin connect.
Posted : 16/02/2014 10:47 am
posts crossed. I'll try that. Cheers!
Posted : 16/02/2014 10:49 am
Gpsies works for me
Posted : 16/02/2014 10:52 am
woohoo! I'm off to ride a very long way. Hopefully.
Thanks again! 😀
Posted : 16/02/2014 10:53 am
