Semi Integrated Hea...
[Closed] Semi Integrated Headsets- do I want one ?
[#2146257]
I want to lower the stack height on my new old 2nd hand frame, to get bars lower and hopefully allow use of existing forks with shorter steer. Its and Older Heckler 135mm headtube & forks with 1 1/8 steerer.
Am I right in thinking-
Intergrated- bearings press right into frame, need specific frame & headset (not what I want)
Semi Integrated / Integral-cups and bearing press into ‘normal’ frame, can be used to lower stack height. Bearings prob wont last as long.
Posted : 01/11/2010 12:33 pm
you're wrong.
you need a wider head tube for all semi/integrated headsets.
Crank Bros Headset is the best bet to lower stack height on a standard frame.
Posted : 01/11/2010 12:36 pm
bugger.
Posted : 01/11/2010 12:40 pm
Also consider getting a stem with a low stack height too. FSA do some with pretty low heights.
Posted : 01/11/2010 1:16 pm
+1 WW and Bigyinn
Posted : 01/11/2010 1:20 pm
i'm an idiot.
i'm pretty sure i've seen steerer-extenders...
Posted : 01/11/2010 2:26 pm
Even at my new idave fighting weight thats not somewhere I want to go.
Posted : 01/11/2010 2:54 pm
