Sektor Springs
[Closed] Sektor Springs
 njm
[#3808507]
Does anyone know if the Dual Position Coil Sektor takes the U-turn coils or the fixed coils?
Also, has anyone come across anywhere selling them with a different spring fitted?
Being a large chap I'd be needing the X-Firm spring I reckon.
Posted : 25/03/2012 10:18 pm
 LoCo
Yes the Uturn coil will fit in Dual position forks and vice versa.
and yes I can also supply the forks with a different rate spring fitted for a small additional charge ( the forks are also fully stripped checked and adjusted (including bushes if necessary) other higher spec. dampers can also be fitted to the sektors, the most popular being the Revelation RCT3 Dual flow rebound damper that will improve performance of the fork and stop them 'packing down' so much on repeated impacts.
Posted : 25/03/2012 10:24 pm
I have the 2011 110-150 Sektor U-turn and want to change the spring from the standard Medium to the FIRM. Anyone know where I can order this from? Thanks.
Posted : 13/04/2012 2:19 pm
markh if you want to buy new then Loco is your man,if you dont mind buying secondhand then i can sell you mine for £30 posted as i dont have the forks anymore.
Posted : 13/04/2012 3:07 pm
Thanks Noidea, I'll take your firm spring. Email address in my profile.
Posted : 14/04/2012 10:06 am
Hi Mark,
I have dropped you an email regarding the spring
cheers
martyn
Posted : 14/04/2012 5:18 pm
